Where do I fin the hydraulic resevoir to return hydraulic fluid from a post driver?
Jmzourt1
Loader, rotary cutter, finish mower, box blade, driveway scrapper, post driver
Aug 17, 2014
Portland indiana
:(I just bought a pd80 post driver an put it together and need to know where to return the hydraulic fluid. I don't know alot about rear hydraulics and can't figure out where to return the fluid
2,556
look here and see if this helps:
http://images.kencove.com/documentation/PD80MANUAL1-10-13.pdf
Need to know what model you are hooking this up on :D. But I guessing you will have to "break" the connection at the 3pt and there you have the pressure in and pressure out connections.
6,416
Jmzourt1,
Need more info, tractor type and model to start with.
Where did you get the supply from?
Kubota's use a closed loop open system, so if you take fluid from somewhere you have to put it back in the same place in the loop. :D
Pictures always help! ;)
