Where can I buy a hydraulic coupling for my M7060HDC12?
KubtCliff
M7060HDC12
Dec 20, 2022
Ep4v8jok!
My coupling broke off the other day and I need to get a new one quickly. I have the number from the coupling but I can't find the specific part anywhere. The part number is 3cfpv-4sfpv-16e1, does anyone have a clue? Thanks so much,
Cliff
8,158
You need to give us a little more info, like where was the coupling, what part male or female, picture?
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,420
1,704
Kalamazoo, MI
This is what's on my M5660 rear remote couplers
Faster 74/38G-19H1
3CFPV-4SFPV-19HO
19H
HEW
ISO 7241-A
4,771
Cliff
That is a Faster 3CFPV coupler - Valpariso Hydraulics is a stocking distributor. You sure about that part number - it doesn't match anything I can find. When I inquired early this Valpariso was having difficulty getting 3CFPV couplers from Faster but if you are lucky he may have that one in stock.
4,771
Cliff
After going back through my Faster catalogs ISTR that Valpariso told me that Faster had discontinued the 3CFPV couplers and the replacement was the 3CFHF which is their new high flow (HF) version of that coupler. Its been a while so don't hold me to that.
Bottom line your old coupler is a ISO 7241-1 Series A interchange with push/pull and connect under pressure when rigid base mounted. If you can ID the port thread on the valve it screws into it would make things easier. A quick measurement of the diameter of the broken off male portion would narrow things down.
BAP
Dec 31, 2012
2,852
946
Apparently, he didn’t need help bad enough to come back on here. Click on his/her profile and the location looks a little suspicious as to whether it is legitimate.
