Wheel and tire wt
DONLI
L3301,FL, MUSTANG 2054 SKID STEER, 6FT HYD. SNOW BLOWER,and other things of labo
Jul 28, 2025
26
17
duluth mn
Can anyone tell me how much a 15x19.5 R4 tire and wheel weigh without ballest?
Thank you
Don
3,483
Thank you
Don
Did you try Artificial Ignorance ..??
“A 15x19.5 R4 tire and wheel assembly can weigh between 104 and 170 pounds, depending on the specific tire type and construction. A tire only, without the wheel, can weigh between 104 and 170 lbs,”
I guess they must have weighed it with an invisible wheel.
DONLI
Jul 28, 2025
26
17
duluth mn
From what I found it will weigh between 225 to 239lbs per tire and wheel.
Antifreeze will add about 279 lbs per tire, to a total of 504 to 518 lbs per tire.
Is that enough rear ballest for an L3301 HST with 525 FEL?
What is everyones take in this?
Don
3,483
Don
You don’t mention what you are trying to lift that requires ballast…but unless you’re trying to lift over 2K pounds….(and a 525 loader isn’t rated for that much)…. You may not need ballast at all.
Ballast is a lot of expense and trouble in my opinon. My tires have air in them. Nothing else.
I typically lift 1500 lbs with my 1002 FEL and never have any problems. (if you DO lift so much it makes you too light in the rear-end…use 4WD …make no fast or sharp turns….and keep the load LOW.)
DONLI
Jul 28, 2025
26
17
duluth mn
My property ( lawn ) is not level if I try to go up hill ( not steep ) with only 50 to 100 lbs in the loader I have to use 4wd.
If I have my forks on and trying to lift anything the rear gets light fast!
I had a L3010 that had water in the rear tires (420-70x24 tires) and if I did not have the BH on or nothing on the 3pt it still got lighy if I was moving gravel or wet dirt!
I do not have anything on the 3pt on this tractor except a middle buster used foe cleaning my ditches.
I have a hard time trying to dig up sod on level ground!
Don
Trash Panda
L2501
Feb 18, 2022
51
Wyoming
Expensive?
I filled the tires of my 2501 for under a hundred bucks.
