What tractor will my 2003 bL4690A backhoe Attachment fit?
B2910Baby
B2910HST with loader and backhoe
Mar 7, 2020
Manchester
Hello folks ,
I have a 2003 B2910 tractor currently set up to blow snow pretty much only and looking for a tractor to do my road maintenance (300 yard dirt road) . I have three point blade and rake and most of the tractors I am looking at have bucket loader . I just love my backhoe it has pretty much moved and dug anything I have thrown at it . If someone could point me in a direction I can go to fit my backhoe on different tractor that would be great. I do not want to waste your time's with each tractor I have looked at .
Backhoe BL4690A
Thanks
5,427
I'm not much help, but maybe can point you in the right direction.
Go here:
https://apps.kubotausa.com/illustrated-parts/
Agree to the legal stuff, then put in your backhoe model number.
Don't open the parts book, but there should be link for "Models" that will show you compatible tractors.
Now with a 'hoe, there might be some different subframes to connect it to the tractor...just something to investigate as you proceed.
Good luck, and welcome to OTT!
wgator
L4701HST, FEL and other stuff.
Jul 28, 2018
482
147
NC
Welcome to OTT B2910Baby.
Another way to see a list of tractors BL4690A will fit, CLICK HERE TO DOWNLOAD MANUAL and look on manual page 24 (pdf page 25) and it lists the tractors BL4690A will fit.
6,602
Considering that model will fit any tractor with a Cat 1 three point,
your field is wide open.
Any B or L in the 25 to 45 HP range will do.
Whatever tractor you get make sure you buy the three point top link reinforcing bracket!
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
78
Rocky Face, Georgia
To add to what Wolfman said that model will fit on B, L and M series. You just have to have the correct top link and brackets. And know which set of holes the lower arm pin in to so it will hook up right.
B2910Baby
Mar 7, 2020
Manchester
Okay so you saying any tractor with group above 1 will work with my backhoe?
Also rear PTO hp above 25 HP ?
greeno
B2710 w/LA402 FEL, BL4690 hoe, RB1560, GS1560, Haban 5' sickle bar, 5' JD RC
Jul 14, 2018
187
Big Lake MN
Download the manual for the hoe, it lists all the tractors it will fit (at time of publication).
I have the same hoe and IIRC the mating tractor list is extensive.
B2910Baby
Mar 7, 2020
Manchester
Ok the top link is the top three point connecting pin correct?
How do I know which connecting top pin I have?
Also the three point I believe is adjustable so that should not be a problem
6,602
Any tractor 25 to 45 motor HP, give or take, with a CAT 1 three point hitch will work for it.
It doesn't have to be just a tractor on the list because it's more of a universal BH, and will fit many more models than they list.
Bulldog
Mar 30, 2010
5,440
78
Rocky Face, Georgia
The backhoe top pins are different from the standard pins that come with the tractor. It should take 2. One the top link hooks over then you put the other in.
Depending on the tractor is what 3pt holes are used. One set is for a B. One for a L and one for a M. You need to be sure you have the correct top link because they are different lengths for each series tractor.
B2910Baby
Mar 7, 2020
Manchester
OK also ran across that I might need a sub frame kit looked around online had no real information on them. What sub frame kit would I need for a L3010 HST? Does this look like it has a reinforced upper pin for my three point backhoe?
6,602
I would love to tell you to get the subframe kit, but that backhoe never had a subframe kit made for it, you could make your own, which is a much smarter option than the three point, but it's not easy.
You need to add the reinforcing bracket to the tractor for the upper pin, it won't come with it.
All the bolts and washers you need to find locally
#5 P/N 70050-94877
#19 (2) P/N 70050-94887
#8 P/N 70050-94384
#9 P/N 70050-94385
