What tools/wrenches to do basic maintenance/servicing on L3902?
ben_2000
17
San Francisco
So I have the usual tools/wrenches to work on car/motorcycle and stuff around the house but realizing they are generally not large enough to do basic work on my new L3902. Does anyone have a good idea of what sizes/tools I should get or a suitable set from Harbor freight to cover most of what I would need?
thanks
Ben
5,172
thanks
Ben
Harbor freight will be your friend, for most any tool you may need
ken erickson
Nov 21, 2010
1,254
2,150
Waupaca Wisconsin
If your L3902 has the turnbuckle style lift arm stabilizers get a 24mm open end wrench. A larger/longer adjustable wrench can be hard to get in and on the turnbuckle jam nut depending on what tires your running. I have R4's on my L2501 with no spacers and it gets really tight on space.
I know the top link adjustment jam nut is larger than 24mm but I use my adjustable wrench for that one. It is easy to access.
The category 1 lift arm pins on one of my implements uses a 1 3/8 inch imperial nut to secure to the implement. I had to buy a 1 3/8" deep well six point socket 1/2 inch drive for that one. The nut is recessed in the frame work and not accessible with a box end wrench etc.
Other than that a normal set of 3/8 and 1/2 metric sockets and set of combination wrenches should cover 90% of fasteners for normal adjustments, maintenance etc.
2,043
You will need to get sockets and wrenches above the normal car sets that usually stop around 20 mm or so. Get up around 20 up to 28 mm or so and you should be good for almost everything. You might want to just get impact sockets but be sure you get 6 point sockets for the larger sizes so you don’t round off the corners.
Blue2Orange
BX2380 with LA344S & QH05. SB1051. SG0554. BB1248. RB0560, Vassar dirt bucket
Apr 3, 2025
134
62
Bayview Township
Bit OT. Discovered as expected the sets of metric and imperial size sockets and wrenches were on the too small size. Decades ago there was a Sears store a short walk from work. After work walked over on a regular basis to Sears. They had a section of returned and odds and ends tools. Slowly acquired the additional wrenches and sockets. Also, larger beam style Craftsman torque wrench. Unsure if the Sears Robogrip pliers were real or just Sears branded. Don't remember if purchased at the Sears store. Handy tool that sits in the tractor tool box. Bit like channel lock pliers.
Mix of brands sitting in the tool cabinet. Real Craftsman, SK, and Tekton. One amazon generic purchase. Finally bought a real Milwaukee impact wrench. Needed some deep socket impact sockets. I sure hope the amazon purchase don't break.
The Tekton tools out of Grand Rapids, MI are manufactured either in the USA or Taiwan. Seem to be decent quality. Free shipping for orders over $25.
Blue2Orange
Apr 3, 2025
134
62
Bayview Township
Rubber mallet in the tool box. I use it too bonk myself in the head when I do something stupid on the tractor. Keeps me from repeating the same stupid thing again. Usually.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,236
1,845
WestTn/NoMs
thanks
Ben
If you have a brush cutter, the nuts holding the blades on and the rear lug nuts will probably be the largest you need. If you're going to work on hydraulic cylinders, I recommend a 3/4" drive socket set.
Blue2Orange
Apr 3, 2025
134
62
Bayview Township
Not an absolute, but makes life more pleasant. Impact wrench. After almost a 1/4 century of knuckle busting and nasty thoughts I purchased a Milwaukee high torque 1/2" impact wrench. Maybe a bit overkill. But beats grunting and evil thoughts. Just beware of all the fake Milwaukee impact wrench sold. Buy from an authorized a Milwaukee tool seller.
Torque wrench in the tool box with capacity to check the wheel lug nuts?
3,443
TRUCK3
53
Upstate NY
Definitely second the 1/2" impact wrench. Picked one up a few years ago after 40+ years of breaker bars, etc. I've been buying the Ridgid cordless tools from HD for a few years. Tools are good quality and batteries seem to last quite a while and the only battery that failed was replaced at no cost, no questions asked.
