F FredC New member Equipment BX2200 LA211 Dec 7, 2016 4 0 0 Frankford, Delaware Dec 7, 2016 #1 What is the purpose of the Shut-Off Plug on a 4 position valve kit (BX2014) on a LA211 Loader. Is this for adding hydraulic fluid? Bleeding air?
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 30,632 6,657 113 Sandpoint, ID Dec 7, 2016 #2 No they are not for filling or bleeding air. The extra plugs are for other setup's or possible options.
F FredC New member Equipment BX2200 LA211 Dec 7, 2016 4 0 0 Frankford, Delaware Dec 8, 2016 #3 OK thanks for the info. The heavy plastic washer on the shut off plug decided to let loose causing a hydraulic leak
