What is the circular cap on top of the engine (Kubota M4050)
Baig
Kubota M4050
Jan 13, 2022
Australia
Hi, just wondering if anyone knows what these small circular caps are beside the inspections caps are on my Kubota M4050? I (think) I noticed some oil leaking from one so I tightened it slightly which caused the engine to misfire. I have done my best to undo the damage, but I would like to know what they are called (so I can do some more research), or if there is a way to properly adjust/tune the engine.
Thanks for the help!
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
949
1,254
Pittsburgh
Due to the lack of fasteners on its periphery I'd say those are fasteners holding down your rocker cover. How tightening one caused your engine to start misbehaving is troublesome.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,246
1,031
Williamstown Ontario Canada
My guess is going to be in a different direction than hagrid.
Your engine is equipped with an engine decompression system according to the parts manual.
I am thinking these openings, which are in the same place but of a different style than yours are to allow access to individual valves, to bleed off engine compression to aid starting. Likely under the caps are adjustments.
Dave
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
653
266
Herald Calif.
The valve cover gasket is old now. You tightened it down to stop the leak. Now the decompression portion of the valve cover is out of adjustment. I would replace the valve cover gasket and replace the rubber grommets under the nuts you tightened. This will probably take care of your problem. If not you're going to have to remove the other small covers go through the process of adjusting the decompression portion. I would also adjust the valves when you have the valve cover off. Great old tractor.
Baig
Kubota M4050
Jan 13, 2022
Australia
Thanks, guys! I think you are right about the valve cover gasket, as I have recently seen a small amount of oil buildup right beside the valve cover and some of the rubber grommets look quite old.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
949
1,254
Pittsburgh
Something has been hitting the top of that decompression plunger.
EDIT: that's not the decomp plunger, it's just a stud. Someone's been hitting it like a red-haded step child.
