what do you use to move your deck around?
USAFCaptNH
JD1025R, 54" autoconnect, 54" FEL , 54" snow thower and ballast box.
Apr 30, 2017
22
Northwood,NH
Hey,
When you have your deck off your tractor how do you move it around?
I have seen Deck Dolly which seems a little pricey but looks like it will work fine
Also have seen Larrys mower wheels which is four wheels and a couple of bars that slide thought where the rear wheels go. Looks easy not as pricey (but pricey for what your getting for your money) but again it looks like it would work okay.
Has anyone used either or have something else they do?
Thanks
rkidd
Dec 7, 2015
743
67
Jefferson Ohio
Hey,
Thanks
I made my own set of wheels for mine for around $25.00.
sdk1968
B2601HSD & CK4010HST 4WD/FEL
Oct 19, 2016
929
36
used to be my back....
then i wised up & got one of those $9 dollys at harbor freight & started using that.
next stop was using the FEL & a strap.
Ramos
1870-1, LA203A, RCK54
Feb 25, 2016
463
Sherman County, Oregon
I just move mine around on it's own wheels in the shop. When it's time to go vertical for longer term storage, I use the loader and leave it leaning against the wall. If your' tight on space, this would not work very well.
USAFCaptNH
Apr 30, 2017
22
Northwood,NH
I just might do that. When it comes off for the winter I wont be moving it until the grass is ready...thanks
Utopia Texas
Kubota B2650/Kubota L6060
Jun 14, 2017
110
Brookshire & Cat Spring, Texas
I am fortunate to have commercial shelving in my barn that can hold 3,000 pounds per 10 foot run so I use the front forks on my NH T4.75 or a electric fork lift to store most of my implements on pallets off the floor and out of the way. I get some funny looks from friends when they see 850-900 pound tractor implements stored 8 feet up on shelves but it sure make life easy for me and gains a lot of extra floor space.
dandeman
BX2230, LA211 FEL, RCK60B Mower, GCK60BX Bagger; Ford 4000, bush hog, blade, etc
Aug 9, 2013
166
Chapel Hill, NC
www.dan-de-man.net
Below is for moving a bush hog around, not a mower deck, but....
I installed two steel wheel rollers on the front edge of the deck that protrude down just enough, in combination with the swivel wheel at the back to let it roll around on concrete. Also added a push handle grip just above the rear wheel to make it easier...
The rollers are strong enough that if they drag in the dirt while bush hogging, they can take it...
Steve67
B2601-fel, 60"mmm, 5' rear blade, balast box
Jan 20, 2017
344
128
St. Louis, mo.
A while back someone posted pictures of hooks he welded on his deck so it could be lifted with fel . Maybe this member will post again
