Weight and height for 3 point
leeco
B7510
Feb 7, 2012
Parker, Colorado
Has anyone used a 3 Point Hitch Scissor High Lift, Hay Lift with a Bale Spear ?
I have a B7510 and want to know if I would be able to use these two attachments to lift square bales of hay that weigh about 900 pounds and if so how high could I lift them.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
78
Rocky Face, Georgia
I know a 7510 is a little more tractor than a 7100 is but the 3pt on my 7100 wouldn't lift a 4672 Kubota BH off the ground. It weighed about 900 lbs or so and as soon as I hit the lift it would open the relief valve up. I wouldn't want to try and handle bales that heavy with a B series tractor.
B7100
B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Feb 11, 2010
422
Wales
The very fact you mention "how high" seems to suggest you have thoughts for lifting more than a few inches from the ground?
Even if your B7510 could lift a 900lbs bale you would need quite a counter weight on the front and plenty of bog roll at the ready when on the move:D
http://www.tractordata.com/farm-tractors/001/8/6/1860-kubota-b7510.html
leeco
B7510
Feb 7, 2012
Parker, Colorado
B7100,
I have that data sheet on the B7510 and it says that the 3point can lift 1356 pounds. I am hoping to stack a 900 pound bale onto another bale so I would need to lift it about 3 feet. Between you and Bulldog it seems like it would not be a good idea. Here is a link to the implement I was thinking of using.
http://www.everythingattachments.co...gh-Lift-Hay-Lift-p/fc-lift-scissorhl-lb3f.htm
Looks like I might have to upgrade to a bigger tractor
Bulldog
Mar 30, 2010
5,440
78
Rocky Face, Georgia
I understand wanting to get everything out of your tractor. I do things with my L 3000 that I really shouldn't do. Loading hay is one of the worst chances I take.
If you tractor can lift 1300 @ 24" then it probably is over 2000 lbs at the lift point. So roughly you loose 40% capacity @ 24". I looked at the link you posted. Nice looking implement. I did notice a few things about it though. It seems since it uses a top link that it sets the load back another 24". If this makes you loose another 40% you'll be down to around 800 lbs and don't even have a bale speer on it yet. Add the speer and your setting the load back even more.
I'm just making a guess using my own experience with things like this, I bet you won't be able to lift over 500 lbs with the weight sitting so far back from the tractor. Another thought is with the weight that far back I bet you can't keep the front tires on the ground.
I remember this about my brothers B 7500. With the loader off and a 4' bushhog on the back I could grab the brush guard and pick the front tires off the ground by hand.
Bottom line, I really think you will be taking a big chance trying to use that implement on a B 7510. I don't want to hear about one of my orange brothers getting hurt or killed by doing something that a little advise could have prevented. Maybe some of the other guys can help you out more but I don't think it would be a safe way for you to move hay. Good luck with whatever you deside to do.
Kubota Newbie
M4500, New Idea Cut-Ditioner, JD 14T Baler, IH "Plow Chief" plows, Oliver Rake
Dec 28, 2010
533
81
Mount Vernon, Ohio
I believe if you take a look at them, the 3-point scissor lift accessories you're talking about are intended only for tractors with category II 3-point hitch.
I was checking into one for my M4500 to move round bales, but it is only category I.
Makes sense since they're really seriously multiplying the force on the top-link mounting point in a direction it is not intended for on most cat I 3-points(many cat II top link mounts are "solid" rather than the hinged "draft control" types on cat I systems). Bottom line, I thought it looked like a good way to break my 3-point top-link mount. If it was a solid mount... maybe, but mine has draft control.
