Hi;
I have an RTV900X with a V5290 plow on the front. According to the manual it uses a "female quick hitch", part number 77700-04876, code 670590. The plow was new in 2025 so this is current stuff. Nowhere on the Kubota website can you search V5290 or any of those other part numbers. It's pretty bad.
I just bought a used Kubota 3030 with a front mount blower. It uses the same style of wedge quick connect as the plow, but one size bigger. I would like to find an adapter so that I can use the plow on the 3030. The problem I'm having is that depending on where you look, this type of mount is either called a wedge, a female hitch, a quick hitch, or a K-connect. But those terms are also used for a bunch of other stuff. It's very confusing! Really all I need is the adapter. Does such a thing exist?
Attached a drawing of the plow connector. Item 7.
Thanks,
Thanks,
