Water Plumbing Question
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
603
457
E.
my friend owns a home with Winsbro Pex-A cold expansion plumbing throughout.
I know this is an pex-a expansion sleeve type system versus crimp ring pex-b that I am used to at my place.
Does Pex-a cold sleeve expansion and pex-b ring crimp systems use the same fittings ?
thanks in advance with any simple knowledge.
Cheers
S-G-R
LX3310, LA535, rear remotes, third function, R14's
Jun 17, 2020
987
1,893
PEI Canada
Expansion fittings are bigger which is why you need an expansion tool. You can use crimp fittings and crimp rings on expansion pex.
2,285
Cheers
NO they do not - one adv of "A" is that it allow 100% flow whereas "B" uses a fitting that reduced flow.
Fittings are different !
NorthwoodsLife
Oct 15, 2021
1,023
969
Wisconsin
Great question!
Great answers!
I learned something today.
Thank you
5,499
The pipe is the same size:
You can use crimp rings and crimp fittings on Type A B and C
You can only use Pex A for expansion fittings and expansion rings.
You can NOT cross the fittings and the rings as they are different sizes.
Edit: Added NOT!
4,642
You can cross the fittings and the rings as they are different sizes.
Did you leave out the word NOT in the last sentence?
MapleLeafFarmer
Dec 2, 2019
603
457
E.
thanks everyone.... I found a plumbing supply house only 1 hr away that carries all the fittings I need.
Pex-a cold expansion fittings are cheap compared to what Pex-b metal fittings are. The largest cost was the drive. The curse of a remote lifestyle i suppose.
