Water Flange question L2850
Sobrbiker
‘87 L2850 w/BF550 and MF-18 72” box
Aug 19, 2023
22
Casa Grande, AZ
The water range is one part, but mine seems to be seeping at the highlighted line in pic.
Is this actually two pieces pressed together?
I’m probably going to clean it up cold and JB Weld that “seam” as I’m not keen on pulling the water pump to access the flange, even if I wanted to pay the stupid money Kubota wants for a new flange (which I don’t).
4,450
I am getting old and lazy and like to get things fixed right the first time around. If that neck is cracked I would pop for a new one. As automotive parts go $140 isn't all that bad.
Flintknapper
L2350DT
May 3, 2022
1,763
2,216
Deep East Texas
Just find an aftermarket unit or used one on Ebay. Save some money.
Something similar to this:
4,892
JB Weld 'might' work, but you'll have to drill 2 relief holes,grind the crack all the way round, clean it 5-6 times, then apply the epoxy, in two coats,maybe 3. This is best done with the part OFF the engine. The problem is that if the repair isn't 100%, then it'll fail
If the piece is cast, it could be brazed or welded, if it's aluminum it could be welded.
I suspect it's a casting failure and really needs to be replaced.
It'd be a shame to destroy the engine by 'going cheap'.
