NoJacketRequired
WANTED - WANTED - WANTED
Looking for the hardware to mount a mid-mounted mower to B7510 tractor. I have the two big welded brackets that bolt to the tractor frame. What I need is the rest of the hardware - the brackets that slide over the lower end of the 3pt hitch arms, the rods that extend forward from them, the arms that attach to the big welded frame brackets and the hardware that goes across under the tractor. All of the bits and pieces required to make the mowing deck raise and lower via the 3pt hitch.
I've got a good 60" mower but need the hardware to attach it to the B7510 tractor.
Also looking for a B2056 hydraulic control. This is the steel "pod" that supports a hydraulic valve, the valve and fittings. This is typically the hardware one would use to mount a front-mounted implement like a blade or blower.
Let me know what you have!
