vintage B6000 with backhoe project
gertou1
B6000 loader backhoe
Apr 14, 2025
Québec Canada
Newbee to kubota, newbee to tractor. Tractor runs rough and will need much work. But what I have to understand now is the backhoe.
At least 2 cylinders are leaking and I think the reservoir is empty. I dont want to run the machine if oil is too low.
1. Is the red circle on first photo where I test the hydraulic oil level? I got it with that white gizmo, no dipstick.
2. I put a smal dipstick from a car (about 10 inches long) : no oil.
3. Where can I find the specs of the original dipstick? Length and minimum/maximum measures?
4. My manual for 629 and 609B backhoe recommends SAE Type F automatic transmission fluid. What do you think? Should I use Kubota oil?
Thank you for your help.
