Vibration
captmikem
BX2660 MX 4800 and a bunch of attachments.
Mar 16, 2017
152
22
SW Washington State.
Yesterday my bx2660 2012 with about 300 hours, developed a vibration. no attachments, not moving, I feel it around 2000 rpm. Very slight, but there.
I can feel it in the steering wheel and through the seat.
Any ideas?
M
JackJ
BX1870-1
Mar 14, 2016
264
9
Indiana
I'd first check your fans (hydro and radiator) and your fan belt for any signs of wear or buildup.
majorwager
MX5100 FEL ford 1620 FEL International 484 FEL Lull 844C
Vibration in seat and steering wheel. ?
Suggest gloves and a gel seat pad.......
No implement attached w/ the PTO engaged? Noted!.
Could it have been the phone in back pocket?
Why sit still @ 2000 rpm and no implement attached?
ipz2222
L235, bx2670
May 30, 2009
1,927
chickamauga ga usa
The bx has a tendency to vibrate on a side hill, the motor leans over and touches a bracket,, quite common. Raise the hood and look for something barely touching the motor.
6,687
Major....that's good!
captmikem
Mar 16, 2017
152
22
I noticed it When mowing. I stopped, disengaged the MMM, and throttled up slowly to see if it was the mower, that is why I was sitting still with no implement attached at 2000 rpm.
checked the fans and belts,
I have noticed it is at idle as well. Think I will check the injectors
M
5,481
2,182
Check the drive shaft between engine and HST for looseness. Check the coupler mounting bolts at the engine, 3 of them, each has a 12mm head as I recall. Seen a few folks post recently about them being loose and/or missing.
captmikem
Mar 16, 2017
152
22
Checked the coupling bolts, I got about a quarter turn on one, others ere tight.
A little bit of runout on the driveshaft but not excessive. There was a buildup of grass between the shaft and the plate under it. no play in the shaft.
Vibration is interment. I used it for about an hour or so yesterday and only once, for about 5 minutes did I have the vibration.
Thanks for the suggestions, I will keep on searching.
M
