My valve stems on the rear tires, on my L245F are located on the inside of the tractor tire. Ive always maintained tire pressure this way, but I dont remember having another tractor with the valve stem located on the inside. The four outer mounting bolts look to be, that they could be removed and I could swap tires, remount bolts, and then my valve stems would be on the outside.
However my question is that, am I better off leaving the stem inside, and its better protected ?
Is this standard mounting procedure for this model of tractor ?
