V3600-eu2
Joytide
V3600-eu2
May 15, 2019
Saxtons River, Vermont,
Hey, first time poster. I’ve got v3600-eu2 kabota that runs a built-rite processor ((cord wood machine) operate at about 2000rpm. Was running it today and it bogged down over about 5 seconds brought itself down to idle (500rpm) wouldn’t rev back up.. Pulled the air filter, changed the fuel filter, oil change ( wasn’t low on oil) nothing has helped so far.
9,143
Is it equipped with a turbo?
Have you checked for fuel flow though out the system up to the injection pump?
Have you checked the air intake filter?
9,143
Pull the fuel line directly at the injection pump and bottle feed the injection pump just with gravity from above it and see what you get.
Does the stop solenoid internally or externally control the injection pump?
Might need to remove it and see how it runs with it out of the equation.
Are you 100% sure the fuel is not contaminated with something like gasoline?
