Using rear PTO stationary
RalphVa
738
320
Charlottesville
Is it like this (from Op manual):
1. Apply the parking brake.
2. Make sure the shift levers are at NEUTRAL, and start the engine.
3. Set the PTO select lever to rear only position.
4. Set the PTO clutch lever to engage "ON".
5. Set the engine speed to provide recommended rear PTO speed.
6. Get off the tractor and place blocks at the tires
On the last two JDs, I could do all this standing on the ground with seat in place. On the 1st JD, I had to strap down the back of the seat.
Personal experience using pump or wood chipper?
It was actually dry enough yesterday to use the chipper again, but we had other things to do. Snowing now again.
7,154
On some models it also requires you to flip the seat up.
jyoutz
Jan 14, 2019
3,151
2,183
Edgewood, New Mexico
On my MX, you have to set the parking brake, then push the stationary pto button on the dashboard.
5,287
Do whatever the manual says, careful though...
On my other tractors I just pull lever back, PTO spins....factory fresh...NO stupid safety interlocks...
4,342
Between myself, my father, and my brother we have 5 tractors. Every one of them is at least slightly different on stationary PTO procedures. Do precisely whatever the Operator Manual says.
SDT
multiple and various
Apr 15, 2018
3,269
1,054
SE, IN
One of the very first things that I do upon taking delivery of a new tractor is to defeat the operator presence switch.
SDT
RalphVa
738
320
Charlottesville
The rear PTO instructions in the operators manual do not work. Had to tilt the seat up against the steering wheel. Then the rear PTO could be used.
