Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Greetings all.
I have a slight problem with my current B6000 project, I need some info on it.
As some of you may be aware I aquired a genuine Kubota dozer/grader blade for my B6000, it required some (I thought ) superficial work to bring it back to serviceable life, man was I wrong about that…..major cutting and refabriacting sections that were totally shot , welding it all back on , way more than I anticipated to be honest, but hey, I like a challenge.
Anway I have done 75% of the work , the subframes finished and the blade section I am working on now and the rams ready to refit.
The issue I now have is that the blade etc did not have the ram mounting plate that fits to the front of the tractor and supports the ram bottom mounting point.
I could make something from scratch if really pushed , but I really prefer to make it to the same spec etc as the original, that way I’ll know that the blade working height/drop etc is correct as factory designed.
To make things a bit harder I have trawled the web etc looking for another to no avail, cant find any pics or details either, so I have drawn a blank.
Pleeeeeeeeeeeeease, if anyone on here has one or details of one can they reply to me or put the details up on the board here.
Don’t confuse this with a snow blade etc , its made to fit the B6000 only using the subframe and loader side uprights or an adapter plate of the Kubota K-450 FEL.
The pics are to large to put up here for some reason so please check them out on this webpage.
Thanks
rob
Thanks
rob
