upgrade from B2100 - more power?
Rich_S
B2100
Apr 19, 2013
SW France
Hi all you clever peeps,
I have a B2100 with belly mower and also a 4ft rear mount flail mower and although the tractor is fine on the flat with the flail it does struggle through the long grass.
I have been looking for a replacement kubota with more power, but I am somewhat confused and need your help.
Assuming a second hand tractor of about the same age then what would be the best use of my money?
Is there much difference between a B2100 and a B2400?
What I am also confused at is the B7600 which also seems to be 24hp
then there are the b2710 and b2910...I assume that these are new years of manufacture. Essentially is there a particular version that stands out above the rest and would be a good replacement for my B2100?
thanks for the help in advance
Rich
8,489
What you need to look for might be a little off from what you'll find as your in France and you have some different units than here in the US.
3 HP differance between a B2100 and a B2400, so not much gain.
We don't have a B7600, but a b7610 (much newer than B2100)
The lower 3 are my picks for good HP and good features
B2710 - 27 HP 2000-2005
B2910- 30 HP 2000-2005
B7800- 30 HP 2003-2008
Rich_S
B2100
Apr 19, 2013
SW France
great, thanks for that, was getting all my tractors confused! It's really what I can find too, not sure that it's that easy to find 2910 and 7800 with belly mounted mower decks for some reason...
