Understanding Kubota part numbers
ArmyChief
L2900f
Nov 27, 2013
Leesville, La
The example I am using is for the engine oil filter on an L2900f tractor. Are all of these filter part numbers the same filter?:
HH164-32430
17321-32430
HH150-32430
15841-32430
1C020-32430
HH1C0-32430
I could not find what the first 5 of the part number denotes. Does it refer to a model number...like all L2900f parts start with HH164 as an example and the the last 5 digits are the actual part number.
lsmurphy
B7001
Oct 19, 2012
1,197
Parrrottsville TN
Who knows? Who cares? Just pick one.
KUBOTA HH164-32430 replacement oil filters:
  • AC-Delco PF2140
  • AMSOIL EAO41
  • AMSOIL EAO43
  • AQUA POWER 6008
  • AUTOEDGE AL7328
  • AUTOPAR FE190
  • Baldwin B1434
  • Baldwin B163
  • Baldwin B7152
  • Beck/Arnley 041-8091
  • Beck/Arnley 041-8145
  • BIG A 92311
  • Bosch 3321
  • Bosch 72138
  • Canadian Tire 17-1742-0
  • CARQUEST 85311
  • CARQUEST B18
  • CASTROL CAS16
  • CENEX CO2904
  • ChampLab LF521
  • ChampLab PH2904
  • CHRYSLER 5281090
  • DEFENSE DL7328
  • DEUTSCH D336
  • Donaldson P551042
  • Donaldson P551268
  • Econo Lube L10018
  • FIRESTONE PH2904
  • FLAG C-2844
  • Fleetguard LF3400
  • Fleetguard LF3706
  • Fleetguard LF3758
  • Fleetguard LF3795
  • Fram PH7328
  • GRAND PRIX PH2904
  • Group 7 L17019
  • HASTINGS B7152
  • HASTINGS LF142
  • HASTINGS LF304
  • HASTINGS LF490
  • JIFFY LUBE HL7328
  • KENDALL K21
  • KRALINATOR L230
  • LEE LF-2904
  • LUBER-FINER PH253
  • LUBER-FINER PH2904
  • MACK 6432PER17
  • Mann Filter W917
  • MELROE 6675517
  • MELROE 6678233
  • MICROGARD MGL16
  • MIGHTY M2904
  • MILEGUARD MO16
  • MILEGUARD MO7328
  • MOBIL L17019
  • MOBIL M1-204
  • Motor Trend ML16
  • NAPA 1307
  • NAPA 1311
  • NAPA 7730
  • ONAN 122-0185
  • OPEL 2-876-465
  • Parts Master 61311
  • Parts Plus PH2904
  • PENNZOIL PZ-104
  • PERFORMAX PO-104
  • PHILLIPS 66 PP18
  • PHILLIPS 66 WO1311
  • POWER FLO SL14670
  • POWER FLO SL20081
  • PRO/GAUGE PGO-18
  • PRONTO PO-7328
  • Purolator L17019
  • Quaker State L17019
  • Quaker State PO-104
  • SECURITY SO-2904
  • SHELL L17019
  • STP S7328
  • SUPERTECH ST16
  • TRUST PH2904
  • UNOCAL OF1311
  • VALVOLINE VO28
  • VALVOLINE VO53
  • VALVOLINE VO95
  • WARNER PH2904
  • WHITE 156513A
  • Wix 51307
  • Wix 51311
  • Wix 57730
OE Part numbers matching this oil filter:
  • Ford E8NN-6714-CA
  • General Motors GM 2-876-465
  • Kubota 17321-32430
  • Kubota HH164-32430
  • Volvo 3517857
  • Volvo 3517857-3
lsmurphy
B7001
Oct 19, 2012
1,197
Parrrottsville TN
Kubota, like every other manufacturer, does not make their own oil filters.
That same filter probably fits 60 different machines.......different applications.....and is produced by 60 different filter makers.
I imagine with each application Kubota assigns the same filter and then assigns the same filter a different number. Or if they change suppliers they change the number.
Wix makes 'private label' filters, Kubota just puts their name on it.
I would not bother trying to decipher any part number.....who knows.....could be the engineer's kid's birthday?
ArmyChief
L2900f
Nov 27, 2013
Leesville, La
lsm - Where did you get such a large list so fast? I am truly impressed with your huge list of compatible filters.
How about a compatible list for these 3 filters as well or tell me where to look them up my self.
TA040-37710 (Hyd filter)
15521-43160 (Fuel filter)
T0070-16323 (Air filter)
The tractor supply store here charges an arm and a leg for genuine Kubota filters and takes forever. But we have a NAPA and 3 other Auto stores which probably stock compatible other brand filters. Thanks for the Help !!!
lsmurphy
B7001
Oct 19, 2012
1,197
Parrrottsville TN
All are here-
Wix
http://www.wixfilters.com/Lookup/Applications.aspx?Section=4
Filter Lookup - By Application
Select Make, Year, Model/Engine of your vehicle to see part listing
OR
PartPart No.Filter LocEngineVIN CodeComments
Air Filter 46483
L2900F w / Kubota D1503LA Engine
T007016323
Air Filter 42985
TA04093220
Air Filter 46438
TA04093230
Fuel Filter 33507
1552143160
Hydraulic 57098
3468037710
Oil Filter 51311
7000074035
No product in this catalog has been certified for Aviation use Applications are verified for vehicles sold only in the United States o
lsmurphy
B7001
Oct 19, 2012
1,197
Parrrottsville TN
The above post.........
Wix will not allow a direct link......enter all your tractor info and you will get all Wix cross overs.
You can then take Wix numbers anywhere to cross again.
Wix makes NAPA filters.........pretty good and fair priced.
