Under 40hp tractors that can use L243 loader
bill.anderson
Bx25
Feb 9, 2018
Carnesville, GA
I need a slightly larger tractor. I have a BX24D and was wondering if I could use the loader and backhoe on a larger Kubota.
If I can't what model (older or newer) can also have a loader and backhoe like the BX24
thanks
bill a.
9,372
thanks
bill a.
No the loader and the BH are pretty specific to the model.
To go to a larger model you would be looking at a B and you can have quite a few with a loader and BH, new and used.
PaulL
2,629
1,604
NZ
B26 is the dedicated tractor/loader/backhoe (TLB). It's a commercial/rental machine, and built tough. You can also add a loader and backhoe to the B2601, it's the same size, but not the same loader and backhoe.
If your BX is too small, the normal recommendation is to go up two sizes not one. The B2601 is quite a bit more machine than a BX (I went from a BX to a B2601), but you should look closely at the LX.
