Hello orangetractortalks and thanks for a great site.
I bought a L175 a few weeks ago. I've done (I think) the standard maintenance on it, air filter, engine oil and filter, fuel filter and lines, grease, etc. Been saving the transmission for last. I pulled the level check plug and the trans lube looks new, like it just came out of the bottle. But it's about 2 inches low. I've read about the preferred lube, 80w gear oil or UDT. It looks like the lube has been changed recently but I don't know which oil was used. The guy I bought it from says he didn't do anything to the trans so I'm wondering if there is a way to tell what oil is in it. I have heard the UDT is thinner than the 80w and this oil looks close to 80w in viscosity but is there a way to tell for sure? And what if I mix 80w with UDT? Or should I just drain the oil and put in new 80w? Thanks for any input.
