Tractor stuck
igizzzmo1
47
Elmira, Or
I learned the hard way today that if you have the grapple and the box blade on you don't have the luxury of pushing your self out. It took me 4 hours and a trip to harbor freight to buy a chain and tow strap.
The first time I got stuck I had the bucket and back hoe on so it was no problem getting out.
Correction: I had backhoe and grapple on not bucket the first time I got stuck.
aeronutt
Z725 Mower, MX5200 w/FEL, Stihl 660, assorted others...
Jan 7, 2016
120
Omaha NE
And you violated the standard forum rule for such comments... Where are the PICS?!
3,102
And we aint talking straps and chains that got you out!:D:eek::)
igizzzmo1
47
Elmira, Or
So sorry I didn't take any picks this time. I was so mad. When it finally broke loose and came out I was jumping up and down clapping like a little kid though. Now that would have been a good video. Here is a pick of the first time I got it stuck with grapple and back hoe attached. I just found out this time how to lock the rear dif.
olthumpa
L275
May 25, 2011
1,505
Maine
ya ain't had any fun until you get stuck ;) :D
you have had tooooo much fun if you need help and it takes you several hrs to get out :eek: :( :p :)
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,501
707
Richmond, Virginia
Being humble and admitting you got stuck is good for the soul and once you get over the embarrassment, makes for a fun story later in the day over a nice single malt.
I've gotten stuck at least three times in less than six months.
First time, my tractor had about 2 hours on it and I had to get a neighbor to pull me free. I had completely bottomed out and was thankful I had gotten a skid plate even before my tractor was delivered.
Second time, I was well prepared. I tried throwing some logs under the tires. No good. I have a 2" receiver on the front. I slipped my winch into it and strapped to a tree. Five minutes later, I was free. Next time, I'll just get the winch and be done with it instead of slothing abut in the mud for an hour.
Third time, was digging out of this past winters blizzard. I drove up on to a snow bank to dump a bucket full further away and again, basically sunk and bottomed out. My neighbor was there with his much larger JD. He was unable to free me. This time, I got my pickup out and slipped the winch into its' receiver (the one on the back of the tractor was blocked by the rear blade and taking it off and moving it was out of the question.) Again, simple as pie, the tractor became unstuck.
In some instances, you can use a rope and a chain along with the curl function of the front bucket (or the BH) to pull yourself out but if it is a distance, you'll find it very slow going. Move five feet. Shorten the chain/rope. Move five feet. repeat.
I have 65' of wire rope on the winch, two lengths of AmSteel 50' long and four snatch blocks and six tree straps with shackles. I'll really have to screw up for that to not get me free!:eek:
An added bonus of the winch and snatch blocks is stump removal. The BX25D, while powerful, is still small. The BH, just cannot snap roots that are thigh sized. I am not going to the work of swapping the bucket for a piranna bar. If I try to pull a stump with the winch, the tractor just skids, even with the FEL curled and dug into the ground. But with the winch going to the stump then to a tree back to the stump and back to the tree, not a single stump has failed to yield to that pull. What I typically do is dig out four or five stumps, then with the rigging in place, pull them out one at a time. Makes it very easy.
OBKubota
2014Gr2120,Gr2728Snowblower,Gck5GrassCatcher,agri-FabSpreader
Oct 21, 2014
205
Ontario
The only reason I have a winch and 2-25 foot chains is for when other people get stuck I've never ever been stuck ,that's my story and I am sticking to it. [emoji12]
thedevilyoulove
L3901 HST with LA525 FEL, Land Pride RCF2572, pallet forks, 3 pt carry all
Jan 27, 2016
143
9
Woodbine, Maryland
My biggest fear is getting my L3901 stuck. I don't have any other equipment to pull it out, other than my Tacoma.
William1
Jul 28, 2015
1,501
707
Richmond, Virginia
Assuming wherever you get stuck you can get somewhat close with the truck, you might be OK. One key aspect of being stuck is to accept it and not keep trying to fight it, you'll often only bury yourself in deeper.
With your pickup (with a driver) and a strong rope, you can curl the bucket to pull you five feet, then as you uncurl, have the driver drive the truck forward (or backward - makes 'communication' easier when you can see each other).
If the back of the tractor is facing the way you have to got to get out, careful routing of the line under the tractor often works fine.
Think twice, move once.......
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
11
Gambrills, MD USA
Get yourself a come-a-long or cable puller. I've unstuck many a 8000 lb truck with them. All you need is something to hook to, and enough common sense, to not dig yourself in too deep...:D:D
7,387
Never been stuck...I got it out, so I wasn't stuck.
Might have taken "help"........:p:p
We all been there - it happens!
Ike
Kubota L 3301, Farmall Cub. JD B. Ferguson TE 20
Jul 18, 2015
324
Mich
I use to have to give a class once a year on vehicle recovery in the Army. If you would add one of the winches like was posted to one of these tractors it may pull it apart. I use to run an 18 wheeler over a bank about 50 foot deep and then the operater would pull the cable out and hook to a tree to pull themselves out. Did not take some long to figure out that if they locked the trailer brakes and stepped down on the tractor brakes they could pull a 8 to 10 oak tree out by the roots. Until I started pulling shear pins out of them when not in use it was not unusual to have to have cables replaced weekly because of operator error
