Need to split my L series tractor, could use some ideas on homemade adjustable height stands. And go...
Those won't work, as you need to be able to roll the front away from the rear.https://www.amazon.com/s?k=High+lift+jack+stands&ref=nb_sb_noss_2
Probably cheaper to buy a set than to waste time building something.
Better yet tell the wife you need to buy a car lift. Works great as a tractor stand.
They would work great on one half! Use the fork lift to move the other half, then place on stationary stands. Or jib crane. Or gantry crane.Those won't work, as you need to be able to roll the front away from the rear.
I use Chain falls on an overhead I-Beam with separate trolleys. If you don’t have an overhead beam you could rig one up with a beam and scaffold at either end.
