Tractor shuts off when push accelerator
John G
BX2360
Feb 16, 2025
Illinois
Hi, I'm in need of repair advice.
My BX2360 turns on at the ignition and idles ok. But when I apply pressure to the forward/accelerator pedal, the engine shuts off. The same thing happens when I lightly touch the reverse pedal or the PTO lever. So I can't use the tractor at all.
It's below freezing, so I tried adding anti-gel to the diesel. No luck. Also cleaned out the air filter. No luck. Finally checked and lubricated the safety switches around the seat. They seem ok, but the one at the seat is actually inside the seat itself so I can't get to it without taking apart the seat framing. No idea if that's the culprit.
Any/all suggestions as to a repair are welcomed! Thanks!
7,465
The seat switch is the issue.
Pull the plug and short the two wires to check.
2,630
I am with these guys ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Garvini
Kubota b26 hydraulic thumb pallet forks
Apr 4, 2022
27
Hingham, Massachusetts
I believe i had the same problem some time ago…there is a safety switch On the pedal assembly under the floor…mine sat in a U shaped slot an it had come out so I was not engaging properly
not sure what they call it
7,465
HST switch
