TPH side to side play
GlenOlsen
Looking...
Feb 28, 2021
12
West Central MN
If using a rear implement such as a box blade, how much side to side play is there supposed to be in the linkage? Would turn buckles remove all play?
Thank you.
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
The turnbuckles can be tightened to remove all play but you don't want to do that. You should remove most of the play. The implement should not be so loose as to allow the lift arms to contact the tires. I usually allow a couple inches of play. Others may prefer different amounts.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,411
1,691
Kalamazoo, MI
My manual says to use the slots for rotary cutter, everything else, pick a hole.
