Top link
2,768
Anyone know the length of the top link on a B2150?
Thanks
Dusty
You looking to buy? Or set to a length?
Tractor supply and many AG supplies have them $25 or less if looking to buy - make sure you get cat 1
modeladay
Sold B7100 and purchased a B2150 with FEL
Mar 25, 2016
117
10
Lincolnton, GA
BadDog
B7100D TL and B2150D TLB
Jun 5, 2013
579
Phoenix, AZ
Mine appears to have a minimum length of just over 20". It's currently adjusted to around 21.5 or just under, and I rarely (pretty much never?) have to go very far from that, and don't recall ever bottoming it out. That's pin center-line to center-line.
modeladay
Mar 25, 2016
117
10
Lincolnton, GA
Russ, thank you, I will go out and measure the one I just purchased. I thought it might be too long but maybe not.
I measured center hole to center hole and its 20 inches, so I guess I'm good.
Thanks again
Dusty
socapots
bx2360, Landpride box blade, FEL.
Nov 7, 2015
57
Manitoba, Canada
I just went through the similar questions.
Ended up buying the shorter of the two i found. Have not used it yet. But did have to take some material off the eye to make it fit.
I seemed to see that is common with the non kubota toplinks. Our maybe that's just the princess auto kinds.
edit: forgot to say mine is 20.5 collapsed. I think. Lol
procraftmike
1977 B7100DT w/B219 FEL
Jan 27, 2016
277
10
Neenah, WI
I have a cat. 1 toplink on my work bench. I get about 20" center to center, with it fully retracted as well.
GWD
M7040, L48 TLB, BX2200
Jan 8, 2010
792
17
Northern California
Depending on one's financial status, it is pretty easy to buy two top links that cover a wide range of measurements. Problem solved.
I'd say there are at least 8 to 10 top links in my barn in various stages of repair, condition, and modification.
There is even one that has a CAT2 ball on one end and CAT1 on the other as OEM. Haven't seen one before or since.
That said, a hydraulic top link, like on my M7040, is not so economical to stock up on different sizes!
modeladay
Mar 25, 2016
117
10
Lincolnton, GA
That makes good sense but I just spent 1400.00 on new tires and wheels:mad:
