I've had my BX1870 for a month now, and while very happy with it overall, I've got one issue that's bugging me.
I regularly drive it 1/2 mile on my road to a friend's house, and when moving (relatively) fast on pavement, there's a very noticeable wobble. Seems like it's worse now than it was right after delivery, but I'm babying it less, so maybe I'm just driving it faster where the wobble is more noticeable.
The cause is clearly that the tires and/or wheels aren't perfectly round since the movement is in sync with the tire revolutions. In researching it, I'm seeing this talked about on other tractor forums, but not so much here. But it's apparently common. My old Ford didn't do it though, at least not very noticeably.
I've got OEM turfs, with Rimguard in the rears. Tires have the same psi--14 in back and 21 up front. (Manual says 17 up front, but my dealer recommends more when doing loader work--all the way up to 28.) I don't yet have a big torque wrench, but I've verified that all the mounting nuts are tight.
I think I may be getting a flat spot that's more pronounced on the left rear tire. I can also see that despite the same psi, my two rear tires have a slightly different shape, with the left having a more rounded tread and the right being just about flat. Seems like that's probably a manufacturer's inconsistency, and I think the tires must have come from two different molds since some of the minor markings on them are different. If that's all it is, I guess I'll learn to live with it. I'm curious if it would be the same without tire ballast, and if the ballast sloshing around might be part of the issue.
I don't have any jackstands, but I'm thinking about borrowing some and getting the tires off the ground so I can measure the runout of the rims and the tires. If the rims are slightly off, I'm wondering if a slight adjustment is possible by moving the rim a bit on the lugs. Right now, that's my only hope for a remedy. Not sure my dealer will agree that it's a problem that needs fixing, and it would probably cost me $200 for them to look at it, since I'm some distance away and they made it clear than even warranty work would still require me to pay transport costs.
Has anyone else addressed this issue? Or is it just the nature of most tractors and something I should learn to ignore? The wobble isn't horrendous, but near top speed it's not subtle, either. I'd like to fix it to whatever extent I can.
Maybe I'll try to capture it on video, though I suspect it will appear less significant than it feels.
Jack
Jack
