L logan New member Equipment Kubota B7800 w?fel Jan 7, 2010 34 0 0 US Sep 21, 2010 #1 I have a B7800 w/23-850 14 tires on the front. Can they be replaced with 25- 8.50 -14
DsBota New member Equipment B8200, G1800 Apr 13, 2010 281 0 0 Milton, Ontario, Canada Sep 22, 2010 #2 If you put a larger tire on the front and it's 4wd it will mess up the gear ratio.
Bulldog Well-known member Equipment M 9000 DTC, L 3000 DT Mar 30, 2010 5,440 76 48 Rocky Face, Georgia Sep 22, 2010 #3 DsBota said: If you put a larger tire on the front and it's 4wd it will mess up the gear ratio. Click to expand... Agree fully. It will be a huge mess the first time you go into 4wd.
L logan New member Equipment Kubota B7800 w?fel Jan 7, 2010 34 0 0 US Sep 23, 2010 #4 thanks for the heads up. Had a deal on some 25's but will stick with the stock size.
