Tire sealant
FiremanDan
L6060 ROPS, Wicked grapple, LP RCF2772 cutter, LP BB3572 box blade
Dec 8, 2013
21
AR
Does anyone have any experience with Kubotas tire sealant?
Good?
Bad?
It's just tire sealant?
Thanks!!
LDowney
Kubota MX6000
I have used the green slim tire sealant in my front tires for a while now. Works great. I was always getting small leaks or punctures in my front tires while bush hogging. Now I have the time to return back home and plug the hole without having to do it in the middle of a field.
I bought the gallon of green slim at Walmart for $24. I put 16 oz. in each front tire.
FiremanDan
Dec 8, 2013
21
AR
Thanks for the info!
3,222
Yup on the slime, also some years ago there was a product on the market I dont remember the name but it was designed for off road bikes, they showed running through big old thorns and the juice leaked out and formed a solid plug. The thing was you could use this stuff for road tires as well, something about it rolling around in the tire and not clumping up in one spot to unbalance the wheel
pendoreille
B2620, fel, RB1560, Piranha Tooth Bar
Jan 2, 2015
476
Newport, WA
Our regional tire distributor definitely does not like any of that stuff.
6,217
More then likely, the tire shops hate slime and fix a flat due to the mess it makes when swapping tires. Took one of the kids cars in to get new tires put on it. Kid had used a couple cans of fix a flat on one of the rims. When they used the machine to break the bead, the fix a flat went all over :eek: The tech was pretty mad over the mess on his machine :rolleyes:
LDowney
Kubota MX6000
Slime will rust out your rims, plug a flat.
Overview
Slime Tube sealant prevents and repairs flat tires caused by puncturing objects up to 1/8***8243; (3mm) in diameter. Slime works repeatedly to repair new and existing punctures and is guaranteed to perform for up to 2 years!
Seals multiple punctures repeatedly.
Non-toxic.
Non-corrosive.
Non-flammable.
Non-aerosol.
Water soluble.
FiremanDan
Dec 8, 2013
21
AR
I have been doing a little research on this type of sealant. Not too much though. My dealer offered to include it with purchase of the tractor, he said it works great. Thanks for all the replies!
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
77
Rocky Face, Georgia
I use slime all the time and never had a problem with it. I know at the quarry when we got tires each one got a 5 gallon bucket of sealant dumped in. Every time the tires were changed the rims looked fine. Only issue we ever had is sometimes the valve stems would get plugged up.
SDMauler
2009 BX2360TV60, RCK60B-23BX
Aug 8, 2014
82
Parker, SD
The reason most tire guys hate the fix-flat stuff in the aerosol can is that the propellant used to be flammable. Pop the bead while you have a stogie in your mouth, and KABOOM. Not sure if they still use that propellant or if they changed it, but there are still probably some old cans rolling around out there. In any case, you need to tell the tire guy if you have slime or any other tire sealant so he knows what he's getting into. I've always thought the can should come with a sticker to put on the wheel as a reminder, and a warning.
