Tire chain question.
springsyeti
BX2680 Grand L3560 LA805 PFL 1242 BB2572 SA20 RCR1872 Worksaver Grapple L4479
Mar 7, 2022
17
Colorado Springs
Picked up a Grand L3560 with a cab this spring and the L4479 front snowblower. The tractor has industrial tires and I will be blowing a dirt driveway that is just over 1/4 min long with some steep parts. I was just at the dealer to get the wonky fuel gauge fixed and asked about chains. They only recommend the rear. Most of what I have seen recommended front and rear. What is the recommendation here? The property is N Central CO with quite a bit of snow and below zero temps. Thank you.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,239
1,666
Western MT
I've used only fronts and fronts and rears. I like having both axles chained up better. I find the steering is a little better. Btw, I just have ladder style chains, but they work well on my setup.
top gnome
Dec 12, 2021
459
214
Fundy shore nova scotia
Skidude108
L3240 HST
Oct 20, 2022
17
Maine
I studded all 4 tires and am happy to leave my chains hanging on the wall.
Do you leave the studs in all summer too? Are there any down-sides? I haven't had my tractor through a winter yet but I assume I will need more traction for snow blowing than my R4s will provide without chains or studs.
WoodKutter
L4600 John Deere 750, John Deere 420
Apr 15, 2022
95
55
Vermont and Northern Maine
I think it depends on your conditions. Studs sound interesting and I may try them. In extreme conditions I can't see them replacing chains. On my plow truck my studded snows stay chained up front and rear all winter.
5,804
Mine are studded all the time.
They work great all winter.
I don't have hard or solid surfaces, we have all sand.
mikester
M59 TLB
Oct 21, 2017
3,402
1,883
www.divergentstuff.ca
Yes I left my studs in all year around. I only did a single row down the mid-line of the tread.
The only downside I see so far is that studded tires leave rosette marks on your concrete/asphalt/pavers if you do a lot of turning on the spot. I am a happy camper with them so far.
Tropical Jack
Kubota L3301 w/ FEL & BH, tilt and trim, chipper, box blade, grading blade
I live in the mountains in western North Carolina. I don’t use a blower because my driveway and community roads are gravel. I use a blade on the 3 pt with a 2x8 board bolted on and extending 2’ past the blade. This keeps me from having to get too close to the edge (ditches or steep banks), and minimizes pushing the gravel off.
I have used chains on the front and chains on all 4 wheels. If I could only put chains on 1 axle, I would chain the front. Increased traction and most important for me - better steering control.
Jack
BAP
Dec 31, 2012
2,649
767
The reason they recommended rear chains is that most manufacturers don’t recommend front chains because of the fear they will damage the front axle internal components. Most people recommend using rears or front and rear combined but not front only. I run chains on all 4 wheels on my tractor to help steering along with the necessary traction.
mikester
M59 TLB
Oct 21, 2017
3,402
1,883
Try the studs, they are relatively cheap and you can always chain up later. If traction is critical I'd get the euro style chains with cleats and put them on all four tires.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
901
691
canada
I chain up all four. Not only do you get more traction, the front chains keep the front/rear ratio matched up better.
4,624
I have front chains, but so far have only used rears. With care, I don’t see an issue chaining all 4.
Just need to pay attention.
