Time for new Hydraulic pump?
billyp
Ardmore, Ok
I have a B1750D that I have owned for a short time. The hydraulics, front and rear lose power and speed after a few minutes (and probably are not as strong as they should be from the start). I have changed the fluid and screen (my model does not have filter) and the fluid had water in it. I changed it the first time and missed the two drain plugs on the rear axle which left almost a gallon of the contaminated fluid still in it so I had to change a second time. The fluid now looks clear and clean but I have not gained anything on the hydraulics. It won't lift my tiller off the ground in the rear after a couple on minutes. It will with rpms over 2000 the first time but only lifts it to a drag the ground position after couple minutes. The front bucket has issues lifting a bucket mostly full of wet sand and after few minutes does so very slowly but not to full height and slowly even with rpms over 2500.
There is a very slow drip leak underneath that is probably coming from the seal on the front pto shaft but I can find no other leaks anywhere and I can't see any evidence of foaming. (Dipstick shows no bubbles)
Any suggestions before I replace the pump. Also, can anyone tell me how big a job it is to replace the pump?
The Kubota dealer quoted me $317 for a new pump. Is this about right and/or any suggestions where to order one?
Are the odds good that it will be the pump and not the Hydraulic block or something else?
Any advice will be appreciated.
9,844
Problem could be relief valve, get a pressure gauge and check it.
Changing the pump is very easy, 2 lines and 4 bolts on the mount, back of the injection pump.
