This is a G4000 tiller that was made for G4000 and G5000 Garden Tractors with the CAT-0 3PH. I found a manual to go with it and realized that the drive could be flipped over from a CW PTO to CCW PTO like on a B6000. Needed to convert the 31/32" 10 spline PTO shaft to a common 6 spline 6N drive shaft coupling, some holes for the CAT-1 top link, and bush the lower pins up for a CAT-1. The right angle gear box had to be flipped over, and then the chain case had to be split so the shaft on the chain case drive sproket came out on the left hand side instead of the factory right hand side. The mount for the gear box required relocation to reset the pinion angle and to maintain the chain alignment, as it was offset 1" from center at the factory. The biggest headache on this was trying to split the chain case because the tine shaft inner bearing race was rusted siezed onto the tine shaft it had to chizeled off in small chunks. A torch and hammer would not get it free. Also these self alining bearing housing called flangette halfs that hold the bearing in the chain case are no longer available from Kubota, so don't beat them up to bad when your trying to pry off the tine shaft bearings. The new tine shaft bearing was available from Kubota, and the 10 days it took to get it was the biggest set back on this project. The resulting performance is leaving something to be desired, as the tiller has a tag for a 2000 RPM PTO, and the B6000 runs only up to 1350 RPM. It still gets the job done, just would be more efficient with a new smaller rear sproket turning the input on the chain case. Maybe that will be done next year along with a new chain gaurd. Seems to work better backing up than going foward. If I could do it again, I'd just swapped the side the tines were on and called it a day. It may have ever worked better!
