Thumb
maclean
BX25D
Jun 25, 2014
242
Lowell, Or
Read the reviews... doesn't quite fit. Do you have a welder and a torch? Mod that one...make your own or buy BXpanded...I have the Kubota one and it was ridiculously overpriced...for the $500 I was expecting a hydraulic cylinder and when it came back from the dealer with the pin and slot crap I was astounded...
pinstripefan90
BX25D, FEL&BH, Piranha tooth bar, Bucket hooks, Pallet forks, Back blade
Sep 8, 2017
49
New York
I got mine off eBay looks like the Kubota and only took a little grinding to get it to fit.
Merlinhomeauto, how much was your ebay one, I'm thinking I will probably just get the Bxpanded factory mount one for easy removal if I need.
SidecarFlip
Banned
554
I don't understand the percentage of a 'Thumb' on a small backhoe in the first place. On a full size excavator like a Komatsu maybe but on a homeowner sized machine I cannot see it. Looks like a waste of money to me.
Freeheeler
b2650 tlb
Aug 16, 2018
706
523
Knoxville, TN
The thumb makes it easier to scoop up things like a downed tree trunk. It's possible without the thumb, but takes a lot more skill.
shiraz627
BX23S Piranha toothbar, Underarmor, PFL1242 pallet forks, BXpanded thumb, ripper
Aug 1, 2018
206
Kingsland. GA
I agree a thumb is not that useful on a small machine. I am able pick up most logs and stumps with the curling action of the bucket. You can only move something so far. There are no rocks where I live.
shiraz627
Aug 1, 2018
206
Kingsland. GA
What I do is get the object of interest in a good position then pick it up with the loader. Without a grapple it's a tricky operation but the toothbar helps.
Freeheeler
b2650 tlb
Aug 16, 2018
706
523
Knoxville, TN
If I'm clearing trees, the bucket is usually full of limbs, limbs piled up across the loader bars, and I use the backhoe to pick up the trunk before heading to the burn pile. I could just use the loader, but hey, the backhoe is there, might as well use it. Scooping a large trunk takes a little time and practice. It would be much easier with a thumb. I will probably fab one up this spring.
pinstripefan90
Sep 8, 2017
49
New York
Same here, I had my property logged and I am stuck with a large clean up so the more I can move at once the better.
