Thanks in advance for any help.
Will not start. If i keep turning it over then i will get a single backfire through the carb.
What i have done.
Bypassed the interlock switch because it tested to be bad.
Bypassed the PTO switch because it tested bad
The weird thing about the above was that with them connected they still allowed the motor to turn over.
Replaced the Spark Igniter because it tested completely out of spec. each pin i tested showed like 3 to 8 ohms.
All of the new parts have tested good but for now, so they won't be a part of the equation I am leaving the interlock and PTO bypassed.
Removed all connectors and soldiered them directly together.
Set the valves from the flywheel markings and manual steps to 25mm
removed radiator and cleaned spot on flywheel with emery cloth and the magnets on the Igniter Pulsars and put a very thin layer of dielectric grease.
gapped spark plugs at .025
Now i have very strong spark from coils and the spark plugs
Compression on both cylinders exactly the same at 140 (this is the only thing that worries me because manual shows should be 170psi)
I tap some starting fluid in the carb to make sure its getting fuel.
Another odd thing is the steering wheel has the issue where it turns while starting. It seems like it resets fine but after about 3 seconds or so it starts
turning to the right again
Just looking for some ideas because i am at a loss. Thanks in advanced for the help.
Wes
What i have done.
Wes
