TG1860G / FD590V not starting, not sure what else to check
orangekuby
TG1860G, BX2200
Aug 9, 2019
89
14
United States
FD590V engine not starting. It has fuel, spark, good air filter, and 175 and 180 psi compression. I've read these engines have issues with the plastic cam gears, is there a way to check if the any teeth are broken and it skipped without taking the whole engine apart? The engine was running good last time I used it, now it does not want to start after sitting for a month.
Workerbee
Zd21
Mar 1, 2020
321
185
MN
You could pull your plug and both valve covers. Watch when your valves open and put a dowel down the plug hole to see where the piston is.
rudder35
MX4800, G1800, Bobcat E26
May 22, 2023
45
56
ac3510!??
You using fuel with ethanol? Drain the tank and the carb fuel bowl. Add fresh fuel with Seafoam and try again.
orangekuby
TG1860G, BX2200
Aug 9, 2019
89
14
United States
Its 10% ethanol fuel with stable. The same fuel is used in my other small engines and works fine, but I suppose it doesn't hurt to try a fresh can.
2,445
Is it carbureted or injected? If carbureted then I would also tend to it being a fuel issue.
Good luck and if it is the fuel you should be able to find fuel that has zero ethanol in it. I try to use that in all my small engines with carbs and have had much less problems with them starting after sitting for some time.
9,528
Pull the spark plug squirt some fuel in the cylinder, put the plug back in and crank.
If it fires then you have a fuel delivery issue.
If it doesn't fire you have a spark or compression / timing issue.
I'm pretty sure if you had broken timing gears you wouldn't get any compression.
5,504
2,213
if you have broken cam gear, "usually" (but not always) the compression pressure will be off. I've had them show up a tooth off and still make ~200 psi. Pull the "pan", gear is missing a tooth or two.
that engine has an issue. The carb sits down between the cylinders and directly above the muffler. Gasoline has two different blends for the seasons. Winter blend, and summer blend. Winter blend fuel is blended such that it vaporizes at a much lower temp than summer blend fuel. Winter fuel can boil at temps as low as 80 deg F. So the carb sits there where it's at, you shut it off, the muffler is hot (obviously), engine is hot, fuel boils out of the bowl and the next time you jump on the mower to start it, it's hard to start. You have to crank and crank until the pump can refill the bowl. Remember, gas is made for cars now, and none of it (not even "no ethanol") is made for lawn mowers or any other small engine.
aged fuel, no matter how much sta-bil you put in it, sucks. You get maybe a month or so out of it with sta-bil, and beyond that, throw it out or put it in the car. No good on anything with a carburetor.
make sure the choke is adjusted such that it is actually closing completely. If not, it WILL be hard to start. The choke creates a vacuum through the carburetor which helps pull fuel through the main and pilot circuit. At cranking speed there is not enough airflow generated by the engine to pull sufficient fuel, so the choke MUST close all the way to supplement that vacuum.
Kawasaki changed the fuel pumps up, the new ones are more compatible with E-10 fuel. I like to suggest replacing them even if it works. Also the new pumps on a lot of them now have a separate drain line rather than just a "weep hole". The weep hole was, again, right over the top of the muffler so if it ever leaks, and they do, it's a great way to burn a mower to the ground. New pump has a nipple that you put a hose on and run it down the side of the frame, away from the muffler.
