tapping into hydraulics
Balex
b7100
Apr 29, 2013
New Zealand
Im going to put a remote valve lever onto the b7100
Is the difference between cutting into the line and taking it off the external plug that we cant use the 3 point hydraulics while its in the external position??
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,187
170
Hardisty, Alberta
Yes, pretty much! I'd cut into the lines if it were mine. I would be a good idea to use a control valve with power beyond as well.
seanbarr
B7100DT (sold) - Branson 3520H
Feb 1, 2013
384
Deer Park, WA
Balex, I have the same tractor with a FEL on a separate hydraulic system. I'm in the middle of adding an electrical diverter for the rear and front on QD's. what do you have on your tractor?
kubotasam
Apr 26, 2010
1,211
134
Alfred Maine
You should not need to cut into the line on a B7100. They have a "tap in" block for hydraulics. It is located near the fuel filter on the side of the engine block. It has a cover plate that gets replaced with a different style to allow the hydraulics to be diverted to the remote valve. I am not sure if you can still buy the new cover or not but it is easy to make a new one that will work.
