Tales of the BX25 Hydraulic Oil Change
Flienlow
Kubota BX25D, Kubota U25 mini EX, SVL75,Landpride Grapple,Landpride grading scra
Mar 9, 2015
352
snohomish
My life is little more than a cold cruel meaningless existence in which I am forced to endure daily. It is often fraught with peril and at times…sheer stupidity. The changing of one’s own hydraulic oil is of little exception.
It all starts with a dream. A dream of independence, self-reliance, and financial sensibility. Next comes the questions. “So…How much fluid do I need?” – About 2 ½ gallons I am told. “SOLD!” I exclaim as I grab my 2 gallons of oil and filter and rush home. Fear not, I have a spare ½ gallon in the garage at home. – waste not, want not.
I proceed to jack and block up my newly muddied orange beauty and remove the left rear tire. I crank up the garage tunes and ferret my fat @$$ under my pull mule and proceed to let fly with the oil.
I have 2 drain pans. 1 almost full from engine oil swap, and the other one is empty.
Necessity is the mother of invention. When one realizes that his drain pan is only worth about a gallon and half in a 2 1/2 gallon drain, he finds the will (and necessity) TO GET THAT PLUG BACK IN QUICK!
However... this presents a certain individual a bit of a challenge. What do I do with the oil currently in drain pan? I need to drain more, and don't have a place to put what I do have yet. The devil is in the details for sure and this was bit of an oversight if I am being honest.
So...do I dump all the oil on the weeds like granddad did? Please! What are we Savages? More of a sophisticated lot if I do say. Bio Hazards and such are held in high regard. It’s a no can do Lads. Besides, I have the other drain pain with the remainder of the engine oil it. – It still has room.
Oh so carefully, I skootch the full oil pan out of the way. – Must be delicate here.
Pan number 2 is in place and we let fly again. Until it fills up. Well this definitely forces my hand now. I need to fill 2 of the 3 engine oil bottles up.
I funnel, fill, and slip. Profusely cursing the oily mess, the wife’s folded white towel becomes the first casualty of this great endeavor. (Let’s just keep that between us.)
1 pan full, 1 pan with a little, I make the swap again. (How much oil is in this thing?)
Since I have 1 residual engine oil container that has good oil in it, and 2 full gallons of Hydraulic fluid, I need to find more container space to dump my oil so I quickly find an empty gallon container of laundry detergent.
And proceed to over fill it. – White towel still has a bit of life left in her so we are good.
With the drain pans mostly full I now proceed to add the hydraulic fluid back into tractor. I dump in the 2 gallons and it doesn’t even register on the dip stick. Time for that extra oil in the storage container. – Except it ain’t there. Seems its at our other property (where the tractor is going back to.)
To be perfectly honest, I don’t know exactly how this happened. But in the end with all the shuffling, I had 1- 5 gallon paint bucket, 1- Kubota gallon jug, 1- 1 ½ gallon drain pain, and 1 small container of tide detergent (that was slicker’n 2 ball juice) all full of used oil and going to the oil recycling facility at the local dump.
“Take the trash out of your house, and you will take the trash out of your life.” I was never so happy to see the oil go as well as get rid of the white towel evidence of my wrong doing.
BUT… I still have a lack of hydraulic fluid. Since the oils is at the other place, and the tractor needs to go there; I just load and go. In the shop I find the half full bottle (conveniently right where I left it) and proceed to fill the tractor up. I keep adding and keep adding, but still it does not register on the dip stick. I’m a bit perplexed as 2 ½ gallons are not even registering on dip stick?
I know what you’re thinking. AND Yes, the plugs/filters are fine, No leaks at all.
So… I go get another gallon of fluid. I add about ¾ of that gallon, and now we seem to be fine. When cold, the fluid measures just a little above the ½ way mark as dealer indicated.
Can’t wait to do it again!
2,880
Why does all this sound vaguely familiar?:confused:
2,720
I am still laughing:D.....I thought he was directing a new movie, and I was the lead actor!!!!!:)
Even though - last time I changed the oil in my GMC truck, I had ALL the tools I needed, climbed under once! Nothing broke, no cussing.....15 minutes ....perfect.....I know, 1st time for everything!:p
2,880
First time I changed the oil in my 6.0L Ford, I bought a drain pan like the one pictured below. It has 4 gal capacity, and the PowerStroke holds 15 1/2 quarts, plus a little from the oil filter housing, so just a little under 4 gals, no problem.:)
Of course, if I had thought it through, I would have realized I'd never be able to move it without spilling everywhere when it was filled to the brim & weighing nearly 30lbs- plus the pour spout is low enough that it will begin spewing before it ever fills to the top.:eek:
Of course I realized all this after I pulled the drain plug, so I had to do a high speed sprint to the other end of the yard & back to retrieve another oil drain pan to place under the spout, which I did about .8 seconds before it made a huge mess.
Tooljunkie
May 13, 2014
4,150
Some days i feel lucky to have a hoist and a 15 gallon oil drain.
Excep the day i decided to drain it. Into a couple 5 gallon jugs.
I never let it get too full, its harder to roll around.
So empty oil into firs jug. All is well. Second jug ,simply close valve and swap
containers. No biggie, do it all the time. Open valve and take a comfortable seat to watch it drain. 1/2 jug full,it slows to a trickle. Well i thought no harm in letting it drip. Walked outside to look at a truck that needs a driveshaft and talk to customer for a few minutes.
Retun to shop and see a 4' diameter puddle wher the jug is sitting. Yup, like that hasnt happened before. Wont be the last time either.
An hour to clean up the mess and get rid of used oil.
Now i have a 45 gallon drum, so spill fills ring on top of drum first before pouring over the edge. When am i gonna learn.....
Yooper
3901 LA525
May 31, 2015
1,601
724
NE Wisconsin
Flienlow, are you a writer? If not, you missed your calling! That was an entertaining post!
3,718
There is a fifth dimension beyond that which is known to man.
(Hmm lets see I think I can do this, I have a garage, a hammer channel locks, bent screw driver, and an old coffee can)
It is a dimension as vast as space and as timeless as infinity.
( OK if I push this junk over there , pull the car out side, put the tractor right there, drag my trouble light here. Man where did all this junk come from?)
It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge.
( Why is it so dark under here ,I think I need new batteries in this flash light,, why it the cord so short on this trouble light? 2, drain plugs, theres nothing in the WSM about 2 drain plugs! OMG which one do I take out, what if its the wrong one? I can do this I know I can but what if I mess it up?)
This is the dimension of imagination.
(I didnt think it would be like this, I read all about it in OTT, it looked so easy, I thought I would be done by now, maybe I had better have another adult beverage and think about it some more)
It is an area which we call the DYI Zone.
( Honey do you have the dealers number?)
Yooper
3901 LA525
May 31, 2015
1,601
724
NE Wisconsin
Skeets, you missed your calling too!:D
2,720
I'll have to agree!!
AND you are showing your age Skeets, you ol Rod Sterling! And for those too young, look up ol Ron, and if you get a chance, watch the "twilight zone" almost better than OTT - ok I said ALMOST
7,471
My all time classic :D was out doing field service and couldn't get the service truck with the evac line close enough to reach. Unit had a 7 gallon oil capacity. I only had a 5 gallon pail.
Figured I could put the oil plug in when the bucket got half full. And drag it back to the evac line.
Oil was 190 degrees. All was going good till I burned the snot out of my fingers on the oil plug and dropped it into the now full bucket of oil :eek:
