T1670 blows 20 amp fuse
golfdrtool
T1670A
Oct 26, 2019
Auburndale, Florida
Hello all, this is my first time posting. I have a T1670A lawn tractor that when I start it, it will run for maybe a minute and then the 20 amp main fuse blows. When I remove it, it is super hot. I know there has to be a short somewhere, I just don't know if is in the wiring harness or one of the components are bad. Thanks in advance for any help.
5,386
2,081
Could be a failing regulator/rectifier, bad ground, or short in the charging system somewhere. Welcome to OTT.
golfdrtool
T1670A
Oct 26, 2019
Auburndale, Florida
I wanted to let the forum know that I figured out my problem with the 20 amp fuse blowing. It was a bad connection in the fuse holder. I replaced with new holder and it works great.
6,295
Thanks for coming back and letting us know the solution. That is what makes the forum valuable to others. And welcome.
5,386
2,081
Yes, thanks for posting a solution! That is a rarity on any forum.
On that note, I do use this site to learn as much as I teach, and the knowledge learned from solutions sticks in the back of my pea brain....and I've used it several times. That's why I like seeing solutions posted.
