Greetings all. It saddens me that my first post is a cry for help. But I promise to stick around and share all I've learned with those in need after me.
I have a T1400H. I received it free two years ago. Long story on that. Some other time.
I've been using it for a year - it sat for a year and that's another long story.
The gentleman who gave it to me used it once a year to clean up the leaves in his yard. I'm very fortunate to have a mower in such good condition.
On to the issues.
Today, I decided I was going to change out the fluids. Oil, diff, and hydro.
I replaced all oils with synthetic.
The motor oil - no sweat.
The gear oil in the diff - I only had one quart of 75-90 and one quart of 140. So I put in all of the 75-90 and the rest (it takes 1.6) was 140 weight. Interestingly, it took the entire two quarts.
The hydro - I put in synthetic as well. 10w-30 as the manual calls for. I drained as much as I could with a hand pump. Pulled the filter and cleaned it, then put it all back together and filled it up.
I ran it for a few minutes on a jack and ran the trans back and forth. It sounded horrible and I thought it needed to work it's way in.
Then I took it for a ride. On acceleration, it vibrates, a lot.
Previously, when I let off the pedal, it would come to an abrupt stop. Now it coasts a few feet to a stop. It seems to run well when up to speed, but something just isn't right. Before it was a little noisy in the rear end (tended to groan a bit when accelerating) but it was strong and reliable. I fear that putting new fluid has ruined my beloved tractor. Is there any hope? Did the synthetic do her in? The incorrect and mixing of weights in the diff?
Thanks in advance.
On to the issues.
Thanks in advance.
