Swing cylinder rebuild on 4520A backhoe
Aressea
B7510 Tractor, LA302-1 loader, 4520A backhoe
Dec 5, 2023
Upton, MA
I have been seeing some leakage from my swing cylinder on the 4520A backhoe, so I decided to rebuild the cylinder. In preparation for the rebuild I ordered a seal kit #70030-01325 from Messicks for $136.58 delivered. I started the rebuild and found everything went well until I got to replacing the "O" rings that seal the end caps to the cylinder and found that the "O" ring supplied in the kit was about 3 1/4" instead of the 2 1/2" which would fit inside the cylinder. I called Messicks and they said all the kits they have in stock have the same wrong "O" ring. So, I called Kubota Customer Satisfaction line. They said they don't have the "O" ring part number and can't help me, even though they supplied the kit. So much for Kubota Customer Satisfaction. Be prepared to buy "O" rings to fit, if you decide to rebuild one of these cylinders. I ordered "O" rings from another source; hope they work.
5,188
"Kubota Customer Satisfaction" ??????
Seems as though "Kubota Customer Satisfaction" should be renamed ......Kubota Customer Dissatisfaction !
They should at least offer a small ($10) gift certificate for their MISTAKE, and your trouble.
Donystoy
Dec 10, 2013
737
379
Binbrook, Ontario
If all else fails, go to your Woods dealer and get the kit for a Woods 650 BH swing cylinder.
Aressea
Dec 5, 2023
Upton, MA
Is the swing cylinder exactly the same between the Kubota 4520A and the Woods 650BH?
Donystoy
Dec 10, 2013
737
379
Binbrook, Ontario
The 4520a is a Woods 650 painted orange. Google the 650 and compare it to yours.
