Hello. First post, new member. Bullet point summary up front. Detail and pics after.
* D950 Unknown Hours, Purchased in June
* Started easily, ran strong, exhaust puffed smoke intermittently
* Injector 1 failed - found it was leaking fuel
* New injectors installed for all cylinders
* Still starts easily, runs strong, smokes continuously off idle
* Running for 20-25 minutes at full pressure washing load, engine coolant reaches 220F on gauge
* Want to fix both issues, looking for suggestions on diagnosing problems
I bought a diesel powered, diesel fired hot water pressure washer as non-running, "needs new starter and ring gear." It has a Kubota D950 motor, that is not original to the machine. The pressure washer manufacturer says the machine came with a D722, but the records are old and the machine serial number sticker faded in the sun long ago. The engine the factory installed was smaller than the D950 on there now.
(intake side as received -- P.O. had pulled old 12V lift pump before selling. I don't know/have any history on missing overflow tank.)
Fixed the starter to ring gear meshing ...
I removed the aftermarket starter motor, re-fit the original starter motor, continuing where the original engine-swappers left off massaging the two parts to fit. They kept the original smaller motor's flywheel with ring gear, probably because it had the factory fit hub and double groove pulley bolted to it, to drive the pressure washer pump. They must have worked on sanding/grinding to bring the starter motor centerline (D950) closer to the ring gear centerline (D722 maybe), and I finished what they started. (I did not do the engine swap ... and did not know it was swapped when I bought it.)
Put on 12V lift pump ...
The previous owner had an electric fuel pump on it. Mechanical lift pump was still there, with open barbs, and the output barb had become plugged with debris. (looked like wood chips) Factory papers for the overall pressure washer machine show it came with an electric fuel pump. I bought and installed new electric fuel pump for diesel fuel, new 12V starting battery, and new engine oil and filter. I cleaned the engine air filter, drained the coolant, and installed a new coolant temperature sender and oil pressure sender. When I bought it, there was a disconnected CAT fuel pressure switch in the oil pressure port, and a 215F temperature switch in the coolant temperature port. Unrelated, but I drained and put in fresh non detergent oil in the pressure washer pump. (Still installing the pump in picture below, bolting it down after drilling mounting holes.)
Started the engine ...
With this work, and glow plugging 10 seconds, the engine fired up immediately. The pressure washer did not work immediately, and checking the valves revealed a chunk of debris holding a high pressure valve stuck open. Removed that, reassembled, and the pressure washer started working fine. Up to this point, the focus was just on seeing if everything could be made to run (engine and pressure washer pump). I did notice intermittent puffs of exhaust smoke, but nothing steady, and I had not yet run it long enough to see engine coolant get up to operating temp. The engine had oil pressure. Using a handheld tachometer and a piece of reflective tape on the pump input pulley, I set the max speed stop screw for the governor speed control lever with the pump input pulley showing 1500RPM.
