I have a svl95 and I am having a fuel pump calibration issue. I tried calibrating it but nothing is happening. Upon further instruction we are getting a fuel temp issue where it is reading 5volts which is with disconnected or not there causing it to sh a temperature of -40 deg Celsius.
In order to calibrate the fuel pump certain per another’s have to be met.
coolant temp
Rpm
Fuel temp
all are in range as shown in pictures except the fuel temp.
I have been told this machine does not have a fuel temp sensor and I have not been able to find one.
I would like to know if there is a sensor in this engine that is dual purpose or maybe the texa tool we used to scan and calibrate is incorrect for this version of v3800 engine.
also if anyone has a working svl95 can they scan their machine and let me know if they are getting a fuel temperature reading.
coolant temp
Rpm
Fuel temp
