SVL90 engine harness connector replacement
willyam
tractor, bobcat
Mar 14, 2016
newnan, GA
Looking for a source for engine sensor wiring harness connectors. Boost pressure sensor connector wires pulled out - Kubota dealer says only the complete harness is available for $3600.
There has got to be some automotive/industrial standard for the connectors?
I emailed a few places, even a wiring harness MFG that makes them for Kubota, but got no response.
Ideas? Thanks!
8,572
That's a pretty big pickle :eek: I've had to replace a couple wiring harnesses due to some tater head robbing Peter to pay Paul and cutting off the plug for and egr valve, to get an engine up and running out in the field. My experience is certain key components are whole harness replacements. Ecm plugs, egr valve plugs, ect.
Some manufacturers at least split the harnesses to some key components so if the plug goes bad, all you have to replace is a section of the wiring harness instead of the whole thing. Still costs a grand though :eek:
You could try to locate one being parted out. Also check Napa, they have a master book with different electrical plugs and fittings in it. You might get lucky and find one that matches.
5,501
2,208
Contact dealers to see if they have any old harnesses laying around. If they do, run over there and see if they'll let you cut a connector off. We keep old harnesses for this very reason and it is a godsend in some cases.
Jim L.
869
171
Get your post count up and then post some pictures of the connector and sensor.
There are places that deal in Japanese automotive connectors. With a good picture and dimensions, it may be possible to narrow it down for you.
