M mcdee190 New member Nov 12, 2013 21 0 0 acworth ga Sep 21, 2015 #1 does anyone know if you have to pull the engine on a svl75-2 to time the engine?
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 33,956 9,167 113 Sandpoint, ID Sep 21, 2015 #2 First off, why do you think you need to change the engine timing?
eserv Well-known member Equipment BX24, A1000 Kubota Generator May 27, 2009 2,187 170 63 Hardisty, Alberta Sep 30, 2015 #3 No, the timing is controlled by the ECU via a crankshaft AND a camshaft sensor. Both accessible with the engine in place. ( if it ever was right it still is!)
