SVL75-2 DPF light
DeeDubz
SVL75-2
Feb 18, 2023
So cal
My kubota DPF light seems to stay on. No performance issues that ive noticed. It doesn't seem to regenerate any more or less than normal. Its not throwing a code either. Its got 1400hrs. Should i be worried?
sheepfarmer
Nov 14, 2014
4,449
677
MidMichigan
Which light are you referring to? How about a quick photo of your dash?
UpNorthMI
May 12, 2020
850
568
Up North, MI
Have you cleaned the DPF? Do you have a WSM (work shop manual)? Cleaning the DPF has quite a few pages starting on page G-48. Normally recommend at 3,000 hours.
I have a pdf copy of the WSM, send me your email and I’ll forward you a copy.
Maybe possible temp sensor or pressure sensor issue in the DPF system.
6,367
Yes, worry about it, if it goes too long it will go into limp mode and leave you dead in the water!
