Suspect bad rear wheel bearing on L3010
NatlCh95
L3010
Sep 7, 2014
Buellton,CA,Santa Barbara
Getting a clunk and popping noise on left rear wheel of 1999 Kuboda L3010.
Suspect bad wheel bearing. If so, how involved is the repair ? If it is more than I can handle, any idea as to how much it would cost to have the dealer do the repair
NatlCh95
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
Aside from asking a dealer for an estimate, why not get yourself a shop manual for the tractor. I'd bet Messicks have them. They you can see what is there and maybe a section on tearing it down.
whitetiger
Nov 20, 2011
2,941
1,399
Kansas City, KS
Check the wheel bolts between the rim and disc. It is most likely that they are loose.
NatlCh95
L3010
Sep 7, 2014
whitetiger!
I sent a private reply but wanted to post an open reply to give you credit for a correct diagnoses. The problem was indeed the bolts attaching the rim to the disc. One was missing and one was loose. I am having all 4 replaced. Thanks for your help.
NatlCh95
