Substitution of Husco Control Valves
Butch
Kubota 2410, RC60-24B, FL1000- kubota hydrolic front snow blade- plug aerator
Sep 10, 2009
676
147
Rising Sun, MD
I have been told I cannot get a main relief cartridge for my Husco Hydraulic Control Valve on my B2410 4WD HSD front blade. It appears you have to replace the complete control valve.
I even talked to Husco tech support who reluctantly told me the Kubota Husco control valves were proprietary and Husco Corporate would not even divulge the Husco set-ups to them.
The Kubota cost for replacing the Husco valve is more than 4 times :eek:what it should be as compared to mainline off the shelf FEL control valves; therefore I am contemplating going with a Prince LVS control valve:).
What I need to find out is the relief valve pressure setting on my current Husco set-up. The Prince unit is fully adjustable.
The model number of my front blade is Kubota 2019 and the Kubota label on the cover of the control valve assembly is B2056 Ser#10843.
The change out is going to be relatively simple and the best part is.... you can get parts for the Prince equipment.
All this and all I need is a silly main relief cartridge for my Husco...:eek:
Thanks in advance folks.... Butch
