Sub solier L3830
bcbull378
GL3830,fel,brush hog,pallet forks,disc,gannon,auger,springtooth,plow,drag,ripper
Sep 6, 2011
579
32
Ventura Ca
I have a L3830 4wd and would like to purchase a sub soiler for it I do some farming in So Calif I was wanting to know if anyone has any exsperance with a L3830 pulling a sub soiler and does anyone Know where I could purchase a good heavey duty sub soiler single shank ? thank you for any help
pat331
L35, mower, bushhog, cement mixer, grader, boxblade, forks, posthole digger
Mar 31, 2009
298
Ft. Worth, TX
I was given an old Ford double shank subsoiler. I have used it a couple of times behind my L35. I can say it will dig so deep that all the L35 will do is spin all 3 wheels and that is with a full bucket of gravel in the front bucket and water in the tires. I could pull it only about 1' deep at the most. I had thought about taking one shank off and mounting the other in the middle of it, but never got around to it. Let us know how you come out. Good Luck!
Hook
L3240 with LA514 FEL, Box Blade, Howard Rotovator, All Purpose Plow, Sub Soiler
Jul 6, 2010
214
Jackson, Georgia
I have a sub soiler single shank and pull it with my L3240. The Kubota pulls it with ease. My previous tractor was 40 hp
2 wheel drive and pulled it also but not with the ease the 32 hp 4 wheel drive Kubota pulls it. Use 4wd, go slow and it will do a good job. It is also useful if you need to dig a ditch. It breaks the ground up and then you can easily shovel the loose ground by hand. A word of caution, you must be careful when sub-soiling as I hooked a tree root with it and broke the top link on my other tractor. Mine is a Fred Cain brand and I purchased it from a Massey Ferguson dealer about 15 years ago. Here is a link:
http://www.everythingattachments.com/Fred-Cain-Tractor-Subsoilers-s/75.htm
cmorningstar01
B7500HST LA302 FEL 5'Finish Mower B5100E 46" Snow Plow 22 ton splitter
Mar 27, 2011
341
81
Pemberton NJ USA
I pull a middle buster subsoiler with my B7500HSD and as long as I do not let it drop too low I have no problems, You do have to be careful of tree roots as Hook has mentioned, If the soil is compacted I make several passes adjusting the depth with each subsequent pass.
bcbull378
Sep 6, 2011
579
32
Ventura Ca
howdy gang
I ordered a Gearmore GR200 single shank ripper ( sub soiler ) should be here 11/02 Ill spend a few days ripping my acreage the next weekend . We have heavy adobe ground here so Im just going to take it slow and go 1 " deep first pass and then adjust from there it has a 23" shank would like to rip the ground at least 18" deep but will see how it goes
bcbull378
Sep 6, 2011
579
32
Ventura Ca
Im picking up my single shank ripper tomorrow after work hope the L3830 pulls it ok in this heavy adobe ground we have I want to rip about 6 acres before the rains come for my deer plot for next spring
bcbull378
Sep 6, 2011
579
32
Ventura Ca
Well gang I picked up my new Gearmore GR200 ripper ( sub soiler ) today after work went straight to the ranch to give it a try before dark. Im more than pleased on how well my L3830 handles it Im ripping 16" deep on my first pass and 23" on the second pass . I realy thought it wasnt going to pull well in this heavey adobe soil but it realy works great.
